wiring interior neonz... WHODUNNIT???
Old Apr 20, 2002
VTECnique's Avatar
VTECnique is an unknown quantity at this point
i want the neons to operate when the door is opened...where can i find the dome light switch wire or other wire that is only active when the door is opened?
Aslo, will i blow a fuse if i do 4 10" tubes? should i only do 2?
Old Apr 20, 2002
djdefcon's Avatar
djdefcon is an unknown quantity at this point
I would say the easiest way would be to pop off the dome light and take it apart and look at the wires that run to it.....and either splice the neon wires to the dome wires right there or folow the dome wires down to somewhere closer to where your neons are...
Old Apr 20, 2002
numbaonestunna's Avatar
numbaonestunna is an unknown quantity at this point
i have wired my car the same way you are talking about, vtecnique. you can simply find the same wiring by the door frame. there is a little rubber button-like thing on each door frame. loosen that up with a phillips screwdriver and use a tester to check the positive and the negative. use that button as your ground and hook up the positive wire of the neon to a constant power source and the neon should turn off and on with the doors. sorry i dont have any pics to show you. but you should see the button-like thing right when you open your door, on the door frame. upon pushing the button you should see the dome light turn off and on, if you have the dome light setting on "door." hope this reply helps you. tip: the driver and passanger doors are independant. the two rears share the same ground. (at least on my car (2001 ex)) good luck!!!
Old Apr 20, 2002
supsoop's Avatar
supsoop is an unknown quantity at this point
or u can go to under the steering wheel column and find the molex that has the wires: GREEN/RED, GREEN/WHITE, tap into thos wires but remeber to use a diode to isolate them, if u need more help just say so, i had to do this when i was installing my alarm with the door triggers.
Old Apr 21, 2002
kano8016's Avatar
kano8016 is an unknown quantity at this point
Diode?!? Huh?!? iso-what?!?
numbaonestunna- thx alot...helped me much
Old Apr 21, 2002
hey np kano. anytime. hope everything works out and lookin good!!
Old Apr 21, 2002
iamboo's Avatar
Retired - SoCal FI Mod
i was gonna wire them to my dome but i just decided on a switch... be sure to use a fuse when you wire that sucker.. in fact... ALWAYS use a fuse when wiring any kind of aftermarket electircal component...
theteju
Aug 5, 2015 06:59 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
