2001 civic valve cover
So, I searched the entire forum and have not found anyone ask this yet. I'm trying to remove the valve cover to change out the gaskets, but holy hell, why did Honda make it so damn hard to remove it? I can't get the hose from the air intake to the valve cover removed. Anyone do this before? I'm downloading the 7th gen manual from the forum. I'll see if it has some instructions for it.
Re: 2001 civic valve cover
The hose is probably compressed on it good. Just take a flat head screwdriver and stick it in between and pry alittle but dont punch a hole in it. It should be easy to get the valvecover off. Its just that hose to the breather, the spark plug wires or coil packs and a couple of bolts.
the crankcase breather hose is always a royal pain to get off of the valve cover. As aforementioned, a flat head screwdriver should do it.
Grasp the hose at the valve cover fitting with pliers and twist the hose back and forth along the circumference of the fitting until the hose breaks loose.
Problem solved!
Problem solved!
Thanks guys. I finally got it off yesterday, and it was a pain in the ***! Actually, the whole process was painful. The area is a tight fit, and there was overhanging lip from the air intake manifold area that made it a bitch to get the cover off. I have to finish the work today after writing my final paper. I'm NOT looking forward to putting the valve cover back on.
By the way, my O-rings and gasket seal were completely baked in. It was a bitch to get the O-rings off, but I found a trick. Use a long nose plier and grab an exposed edge (there is an area that exposes a millimeter of the O-ring to grab). Grab it and twist in clockwise fashion. It should bend the ring inward and allow you to peel the O-ring off like a tin can opener.
Finally finished it. Getting the new valves on the bolts were impossible. I could only get two on. I just used the old bolts and valves. Also, getting the O-rings on require a hammer and chisel technique. I didn't think it would be that hard getting those things on there. Besides that, it wasn't that hard to get the valve cover back on.
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
CapYoda
Nov 11, 2001 05:17 PM
