ac hot at idle, cold wen driving
Old May 19, 2010
1sikhatch's Avatar
1sikhatch is an unknown quantity at this point
idk wats goin on wit my car, my ac blows hot as it is idling but wen im driving it gets cold. checked the fan and its working, freon is full
Old May 19, 2010
Re: ac hot at idle, cold wen driving
isnt that normal? the compressor works better when the rpms are up. every car ive driven blows warm at idle and cold on the highways.
Old May 23, 2010
HD~Silverado's Avatar
HD~Silverado is an unknown quantity at this point
Unless its blowing hot air like as if you had the temp up, that is normal. Mine blows coldest on the highway when the rpms are higher while stop and go traffic will still blow cold air but not as cold as on the highway. Though I only use a/c maybe 20 days a year so I'm not the best judge.
Old May 23, 2010
also our cars (and i think pretty much every car) use a cycling compressor that turns on and off every so often. so when it turns off, you are not getting cold air but just what is already circulating in the car. on a hot day, sometimes the a/c will not even be able to keep up, since everything is already so hot (vent ducts, engine bay, etc).
Old May 24, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
replace the thermostat and check your antifreeze level.
Xuhme
21
Aug 7, 2023 03:40 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
mikemc422
Aug 9, 2018 05:41 PM
jc33312
May 12, 2015 03:17 PM
smmahan
Apr 15, 2015 08:17 PM
