Stupid me... radio harness/wiring question
Old Apr 16, 2010
ngk0325's Avatar
ngk0325 is an unknown quantity at this point
OK. I'm an idiot.
I have a 2004 honda civic lx. I was swapping the oem radio for a sony something along with an amp and sub. My stupid move was cutting all the wires going into the harness adapter for the oem radio because I stupidly thought that those wires would match up in color to the half harness and adapter for the sony radio head.
So - where can I get a half harness and splice all the wires together to get this thing up and running???
Best Buy? Basically, I need to go FROM the Honda colors and wires TO the sony harness but the colors do NOT match up whatsoever.
HELP - MAJOR HELP.
Old Apr 16, 2010
CraigW's Avatar
Re: Stupid me... radio harness/wiring question
How short did you cut ?? Can you match wire for wire and splice connectors back on ??
Someone mentioned Metra makes a factory connector harness.
Old Apr 17, 2010
ngk0325's Avatar
all the way to the end...I'm going to try Best Buy today...
I'm putting in a Sony deck.
Old Apr 17, 2010
CraigW's Avatar
www.the12volt.com has the factory colors.
Avoid using the illumination & dimmer leads if possible.
Old Apr 20, 2010
electric130's Avatar
yes, metra makes a harness that replaces the factory one if it was cut off. put that on and then put an aftermarket adapter harness on the stereo. those colors will match your sony.
OptimisticWay
46
Oct 15, 2015 02:16 PM
Dave1984
Jul 22, 2015 06:10 PM
NoobyKid
Jul 13, 2015 07:53 AM
magog45
Jul 9, 2015 06:23 PM
