1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
89 civic lx tries to start, but doesn't
Old Mar 8, 2010
dedlyvirus's Avatar
dedlyvirus is an unknown quantity at this point
alright, so this is what is happening. when i turn the key, the engine tries to start. And sometimes, it will catch and actually start, but stalls immediately. One time, i got it to start, and it idled fine. i even drove it around the block. it didn't overheat, shifted fine, accelerated normal and everything. While i stopped at a stop sign on my way home, it stalled. just shut right off. i had to push it home and it wouldnt start after that. it just keeps doing the same thing, the engine rotates but doesnt catch.
ive replaced fuel pump, fuel filter. battery is fully charged, the main relay is operating fine. while i was driving it, and when it was idleing, it wasn't smoking or nothing. any ideas?
Old Mar 9, 2010
mygotsampster's Avatar
mygotsampster is an unknown quantity at this point
Re: 89 civic lx tries to start, but doesn't
Does it just die all together or does it sputter then die out? what does it do before it dies?
Old Mar 13, 2010
dedlyvirus's Avatar
well, ive only gotten it started once. when it did die, it sputtered a little bit, so i tried to give it more gas to get the rpms up, but it still just turned off. i haven't been able to get it started again.
i just pulled to injectors to check them, but i haven't done it before. its a dual point fuel injection system, so it said to test the resistance on the plug of the injectors. when i tested them with the ohmeter, it just goes all the way to the right, i guess signifying 0 ohms, which means no resistance, right?
the book says that if the ohms aren't in the range listed in the book, (chiltons) that they should be replaced..should they be replaced? with no resitance showing up?
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Richkid23
Apr 19, 2015 12:53 PM
tattedlariat
Apr 17, 2015 03:26 AM
mrohitredd
Apr 15, 2015 08:13 PM
SSMatey
Apr 13, 2015 06:09 PM
