1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
New honda owner!!!!
Old Feb 2, 2010
brianbge2's Avatar
brianbge2 is an unknown quantity at this point
New honda owner!!!!
Well, I invested in my first Honda last week as a daily driver and she needs a little TLC. It's a 92' SI Hatch !
Anyway, I need to adjust the timing belt but i'm not sure exactly what to do. I'm firmiliar with the engine a little on the outside as I already had to change the water pump . I believe the timing belt is a little loose because as I put load on the engine, the timing belt (coming DOWN off the cam pulley) is flapping around slightly... Enough to where it hits the motor mount, which I believe will eventually wear the belt down. Is there like a belt tensioner for the timing belt I missed somewhere? Or is the timing belt just too big?
Any input would be appreciated..
Old Feb 2, 2010
Re: New honda owner!!!!
welcome, yeah they have belt tensioners, you may need to just replace it cause i think most are auto tensioning.
Old Feb 2, 2010
brianbge2's Avatar
Oh really? hmm... I'm gonna crack into it tomorrow and see. guess i'll just replace it. thanks!
Old Feb 2, 2010
#13 in the pic...plus those small parts that go with it should be replaced.
Old Feb 11, 2010
Fixitpat's Avatar
Fixitpat is an unknown quantity at this point
When you install the timing belt, after verifying that the crankshaft is in the TDC position and the camshaft pulley is lined up correctly...
1. slide the belt on
2. rotate the CRANKshaft with a socket wrench counterclockwise for a distance of 3 teeth on the CAMshaft pulley. (this is what applies tension to the belt)
3. tighten the belt tensioner bolt.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
markp94
Apr 30, 2015 09:19 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
Cross
Dec 9, 2001 05:53 PM
