top of engine oil leak
Old Jan 6, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
I have a 96 civic ex. I have a lot of oil leaking on the top of the engine. I had the valve cover gasket done and oil pan gaskets as well.
In addition, I had the o ring in the distributor just done.
Any ideas where else it can be leaking?
Old Jan 6, 2010
Re: top of engine oil leak
it might still be coming from the valve cover if it wasnt installed properly.
Old Jan 6, 2010
civicpapi's Avatar
I checked the corners of the valve cover, no real wet oil.
I might have to have the dist o ring checked again, right under that area is wet oil, falling on the trans case.
I was wondering if there is anything else that can leak from the area of the distributor and valve cover?
Old Jan 6, 2010
04 Honda Civic's Avatar
Change your PCV valve thats whats blowing all your seals out.
Old Jan 6, 2010
civicpapi's Avatar
I do not think the EX has a PCV valve?
Old Jan 6, 2010
they do, looks something like this.
http://www.clubcivic.com/board/showthread.php?t=68638
Old Jan 6, 2010
civicpapi's Avatar
Interesting, I am over due to change it then. Any tricks to get it out without going under the car, plus I bet mine would break since it is so old.
Old Jan 6, 2010
use a pair of long nose pliars and heat the area first so its not as brittle. or drive the car just before changing it.
Old Jan 6, 2010
civicpapi's Avatar
I was looking at the link, when you say long needle nose pliers, what is the best way to get to it? from the side of the intake, since the area where the hose plugs into is very narrow? Remember I have an EX.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
LionSpratt
Jan 29, 2017 11:07 PM
mievil
Apr 28, 2015 11:02 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
