8th Gen 2006 - 2011.
civic maintanence minder
Old Dec 4, 2009
ac2491's Avatar
ac2491 is an unknown quantity at this point
should i wait for the 30K civic maintanence minder to come up, or at 30% oil should I just get the usual stuff done. with the maintainece minder it might give dealer a chance to charge more.
Old Dec 4, 2009
Re: civic maintanence minder
30k is just a few basic fluid changes like trans, brake, and maybe oil if you need it. coolant you can wait few more yrs.
Old Dec 4, 2009
CraigW's Avatar
I would think at 30k it would be oil/filter, ATF drain and refill, air and cabin filters. Do the air & cabin filters yourself they charge much more than it is worth. You should set your own schedule and ignore the minder.
Old Dec 4, 2009
ac2491's Avatar
By the time I get home it gets dark, will check the fluid levels tomorrow and post it. Doing this by myself the first time, so kind of jumping here and there, actually am quite sick of shelfing out money to the dealer.
And my wife drives the car around 60+ miles every day, so want to recheck everything too and she refuses to open the bonet, I mean literally refuses
Old Dec 4, 2009
ac2491's Avatar
(will sound dumb ) looks like cabin air filter and engine air filter are diff.
The cabin air (a/c) filter is located behind the glove box, got a DIY for that. Will just vaccum the one that the car has one currently for now.
Where is the engine air filter and is there a DIY for its replacement. thnx
Old Dec 4, 2009
CraigW's Avatar
You will want to replace that cabin filter(s) once you see how it looks when you remove it.
The air filter should be easily done also, my 05 has 6-8 screws holding the cover yours should be very similar.
Old Dec 4, 2009
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
air filter is held by 5-6 clips(can't remember exactly) on 8th gen SI....i replaced mine at 10K with K&N...just pollens no dirt...
ATF or MTF is a must...
Old Dec 4, 2009
ac2491's Avatar
http://www.8thcivic.com/forums/engin...r-install.html
this seems to be the DIY for the engine air filter..
Old Dec 5, 2009
ac2491's Avatar
holy crap!! The transmission fluid is black and level is loo. Its the yellow dipstick. And the engine oil is as brown as it can get. All other fluids look fine and full. Engine coolant was too much in front to check and it was raining.
I have to change the transmission and engine fluid immediately!!!!
Old Dec 5, 2009
ac2491's Avatar
should i get the tranny flushed or just drained and replaced? flushed is over 150 bucks and drain and change is much cheaper?
Old Dec 5, 2009
CraigW's Avatar
I would not get the flush, only a drain and refill with only Honda OEM fluid.
I have always done mine at 25k but 30k should be fine.
Old Dec 7, 2009
ac2491's Avatar
thanks guys for the help. Got the oil and tranny fluid changed, also the engine oil filter. Will be changing the a/c filter soon.
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
