1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
cams for a d16z6
Old Nov 30, 2009
sublime0407's Avatar
sublime0407 is an unknown quantity at this point
Arrow cams for a d16z6
okay since x-mas is rollin around im gettin a new cam for my 93 ex and prob new injectors and fuel rail 1.) with the new cam is there anything else i will need or is it just a "drop in"? 2.) where can i get this if so? 3.) the stock injectors on the z6 are 180cc i think , if i get the new fuel rail and am running everything else pretty much stock besides the cam what cc should i go up to?
Make all the comments u want. but i did some research that tweaking ur air/fuel ratio increases hp and torque way more than any dinky bolt-on. Then doing this plus chipping the ecu will have dramatic results!!!
Old Nov 30, 2009
TRIZ's Avatar
Re: cams for a d16z6
Make sure you have some engine management to monitor your changes. If your going to change injectors and fuel rails, I would hope you have something to monitor what % of the injector is being driven at. You might have to upgrade the fuel pump too, not sure about your car. There is hella info on d-series.org for your motor.
Old Dec 4, 2009
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
As for where to buy you came:
http://www.bisimoto.com/
Old Dec 4, 2009
BIG RICH's Avatar
BIG RICH will become famous soon enough
nothing else is needed for the cam....
i agree with twiz, however i do not have monitoring for mine as it is not a daily.
i kept my stock injectors because they can take more than what they are given. after chipping get yourself an aem adjustable fpr and hang it off the rail. take it to a dyno and have them monitor air/fuel and adjust the fpr appropriately. this is how i handled it on mine.
ricer_em2
May 11, 2016 08:09 PM
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
Klame9420
Aug 13, 2015 06:00 PM
