Heater not working
Heater not working
Hey there. I have a 2003 Honda Civic LX, and there is no hot air coming out when dials are turned to full heat and the fan is turend to max. The same thing happens when I turn on the AC. All lights AC and heating lights still come on. Any suggestions? Thanks alot, much appreciated.
Re: Heater not working
how is your coolant level? you may have some air bubbles, or the heater core might be clogged. does the car overheat?
I haven't checked the coolant level yet. The fuses are fine, I feel a little bit of heat coming out of the vents but there isn't any circulation going on. Could the fan motor be busted? My car hasn't overheated yet..
When the fan is on max, I have absolutely no cold or warm air coming out of the vents. When I turn on the accessory power, I can hear (what i believe to be) the fan motor turning on then it stops. I do hear clicking sounds coming from the vents when I turn the temperature **** from cold to hot.
R3KogHyZe
21
Feb 3, 2016 09:23 PM
werdnahall
May 17, 2015 11:37 AM
ORskier
May 3, 2015 12:54 PM
