Fan System Problem
Old Oct 26, 2009
Grizzlybear's Avatar
Grizzlybear is an unknown quantity at this point
Fan System Problem
I have a 1999 civic dx and my fan system wont work at all. I have checked the switches and relays and they all work except where the relay is connected in the interior of the car below the glove box, the relays don't work when plugged in there. any help would be great thanks.
Old Oct 28, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Fan System Problem
Test the switch found plugged into your thermostat housing. That is most likely the culprit.
Old Oct 29, 2009
Where is it located....?
Old Oct 29, 2009
ScottDR's Avatar
Read my prior post, "on the thermostat housing". It's a two pin connected switch that monitors coolant temp. and 'switches' on the cooling fan.
Old Oct 29, 2009
This is for interior fans not the radiator fan right?
Anyways thanks a bunch so far.
Old Oct 29, 2009
you re not getting any air coming out the vents? its either a bad blower motor or the blower motor resistor/transistor. do you hear any sounds when you turn the fan on?
Old Oct 30, 2009
ScottDR's Avatar
OH, sorry Grizzly. When you said fan system I had to assume you meant cooling fan for the engine.
Old Oct 30, 2009
No problem. Ya the fan system doesnt work there is no sound no light, no nothing. It was turning on full blast for a while every once in a while before it completely died. I have tested all the wiring and cant figure out why the second switch inside the car wont work,(the switch works just not in that location).
Old Nov 6, 2009
Well i replaced the blower motor resistor and that didnt fix the problem, so i checked the motor by hardwiring it to my battery and it works great. So after a long period pf testing all the wires i think i have found the problem. The picture below is the silicon chip that is inside the nobb/control box for the blower and there are several spots where it has blacked out and crusted over circuits. So i am thinking i will need a new one. I will most likely not be able to buy just the chip. So i was wondering what the box that houses the chip and the nobbs for adjusting the blower and heat is called and where i might find it.
Thanks
Old Nov 6, 2009
usually ebay sells those ***** and dial pieces for cheap. its easier to just get new parts than to worry about fixing it. you might try wiping the crusted or black areas with alcohol and see if that makes it work first.
dinsum
May 28, 2015 09:30 PM
Lunar
May 22, 2015 07:43 AM
crowtoo
May 11, 2015 06:50 PM
hokiedad4
May 3, 2015 10:06 PM
supercivic01
South
Nov 30, 2001 11:27 AM
