Fan System Problem
Fan System Problem
I have a 1999 civic dx and my fan system wont work at all. I have checked the switches and relays and they all work except where the relay is connected in the interior of the car below the glove box, the relays don't work when plugged in there. any help would be great thanks.
Re: Fan System Problem
you re not getting any air coming out the vents? its either a bad blower motor or the blower motor resistor/transistor. do you hear any sounds when you turn the fan on?
No problem. Ya the fan system doesnt work there is no sound no light, no nothing. It was turning on full blast for a while every once in a while before it completely died. I have tested all the wiring and cant figure out why the second switch inside the car wont work,(the switch works just not in that location).
Well i replaced the blower motor resistor and that didnt fix the problem, so i checked the motor by hardwiring it to my battery and it works great. So after a long period pf testing all the wires i think i have found the problem. The picture below is the silicon chip that is inside the nobb/control box for the blower and there are several spots where it has blacked out and crusted over circuits. So i am thinking i will need a new one. I will most likely not be able to buy just the chip. So i was wondering what the box that houses the chip and the nobbs for adjusting the blower and heat is called and where i might find it.
Thanks
Thanks
usually ebay sells those ***** and dial pieces for cheap. its easier to just get new parts than to worry about fixing it. you might try wiping the crusted or black areas with alcohol and see if that makes it work first.
dinsum
May 28, 2015 09:30 PM
Lunar
May 22, 2015 07:43 AM
crowtoo
May 11, 2015 06:50 PM
hokiedad4
May 3, 2015 10:06 PM
