New fuel tank/gas tank for 02 civic?
Old Oct 22, 2009
leuch3rd's Avatar
leuch3rd is an unknown quantity at this point
Hey guys, i think this in the right place (sorry if it isnt! )
So I hit an object on the highway last night (previously ran over chair) and I realized once I got home that I gashed my fuel tank and was leaking like a mad man. Aside from Honda OEM parts, and repairs which we are looking into, any suggestions on an aftermarket part for a fuel tank??
It is an 02 Civic EX 1.7 if that helps.
Thanks!
Old Oct 22, 2009
Re: New fuel tank/gas tank for 02 civic?
try and find a used one from junkyard or ebay. the aftermarket ones often dont fit right or are missing hardware.
Old Oct 24, 2009
sl33pyriceboi's Avatar
^exactly.
if a junkyard isnt an option, just buy it form http://www.hondaautomotiveparts.com/ which is the cheapest OEM parts seller (that i generally use)
(i believe its only like 176$ from hondaautomotive)
Old Oct 24, 2009
javier_zr's Avatar
javier_zr is an unknown quantity at this point
you should check also the fuel pump, I have the same problem short time ago and in my case the object also destroy the fuel pump assembly and the pump. Well in my case my car stop and doesn't start, if your's does start then I believe is just the tank. My ride is like your's, a 01 civic, for this purpose the same thing.
Old Oct 27, 2009
slapoutz's Avatar
slapoutz is an unknown quantity at this point
you could hammer back to shape and weld the tank back up
Old Oct 28, 2009
Staninator's Avatar
Staninator is an unknown quantity at this point
Yeah... welding a fuel tank???
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
Lightman
Nov 10, 2001 06:44 PM
