Turn Signal Ripped Out
Old Oct 14, 2009
kolpax's Avatar
kolpax is an unknown quantity at this point
I have a 2001 Honda Civic DX that I just bought, but the passenger side turn signal from the headlight is gone. I see the wire that it is suppose to go one, but it looks like it was ripped off or something. I wanted to know where I could purchase a replacement socket to wire in so I can have a turn signal again. Thanks in advance.
PS - Already searched all over Ebay & Parts Train.
Old Oct 14, 2009
Re: Turn Signal Ripped Out
do you need the socket that holds the bulb AND the connector that plugs into it? pretty much the only place is the honda dealer or junkyard. actually i have one spare brand new connector with the wires already installed. you just would need to connect them to the car wires. then that connector would plug into the socket.
Old Oct 14, 2009
kolpax's Avatar
Yea, it is just the socket that holds the bulb. The part coming off the connector is there and the wires that go into the socket is taped up.
Old Oct 15, 2009
oh i dont have any spare sockets. just order from dealer or junkyard might have one. 2001-2003 uses 7443 for the signal bulb. be sure to get the correct part because coupe and sedan have different plugs.
Old Oct 15, 2009
kolpax's Avatar
awesome thanks, and would you happen to know the name of the socket that a coupe would use and its for the headlight right?
Old Oct 15, 2009
kolpax's Avatar
http://www.ledlight.com/t20-wedge-7443-socket.aspx
something like this?
Old Oct 15, 2009
its not exactly the right one, might be loose or have problems later on with the contacts inside. the honda one has a rubber ring on the base to keep water out. i wouldnt go with the generic cheapie ones.
Old Oct 15, 2009
kolpax's Avatar
yea, it starting to look like no one has that piece so i may just make a trip to the junkyard. Thank you very much for the information.
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
