Civic Cluster Color Change
Old Oct 11, 2009
xChinox's Avatar
xChinox is an unknown quantity at this point
I found a thread that explained how to change the color that lights up the cluster simply by putting in a colored plastic in place of the stock one.
http://www.d-series.org/forums/diy-f...e-cluster.html
I was wondering if this works the same for 1997 civic.
I couldn't seem to locate the stock one. help please
Old Oct 11, 2009
Re: Civic Cluster Color Change
depends on the cluster. our 92 accord uses the blue filtered white light from the top like that, and also separate backlighting behind the numbers. some only have a film behind the numbers, or it could be painted on like the newer civics. i think older civics use just backlighting and its part of the gauges plastic. you may be able to clear it carefully from the back with acetone and put different film, but you can really only do this with warmer colors like yellow/red/orange, the darker colors will not be bright enough cause incandescent emits most of its light in the warm side.
Old Oct 13, 2009
xChinox's Avatar
oh ok thanx.
ill probably just change the color of the bulbs in this case
Old Oct 16, 2009
OCDjG's Avatar
OCDjG will become famous soon enough
LoL, I saw that thread over there too. Our cluster has that filter too. You can swap it out for another one just like what the OP in that thread did. If you simply change the color of those bulbs or add covers to them and you don't mess with the filter, then you will not really see a difference since that stock filter is so dark. If anything you'll make the output worse.
Old Oct 17, 2009
xChinox's Avatar
do you know where that filter is located?
Old Oct 19, 2009
OCDjG's Avatar
Yeah. If you look on top of your gauge cluster you'll see the board that holds the two lamps that light up the cluster. When you remove that board you'll be able to see the filter.
usajags84
15
Aug 19, 2015 03:12 AM
TheRubixHorse
Apr 17, 2015 08:55 AM
bahena08
Apr 11, 2015 05:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
meels808
Nov 5, 2001 09:15 AM
