no cat and having lil problem on hp
Old Oct 10, 2009
DjExotic's Avatar
DjExotic is an unknown quantity at this point
i just got this car and i notice first off after two days of buying the car off the used dealer. i was gettin slow hp on the highway. and the engine light came up. i had the car scan and came up with the p0420 code of the cat. so i look at the motor to the headers (their are aftermarket header on this car) but when i look under the car, their is no cat so i been running without the cat for almost a week now.
so should i order the cat or just the o2 senor and then get the cat later that week.
need help real soon.
Old Oct 10, 2009
Re: no cat and having lil problem on hp
well you need a cat otherwise the engine light will always be on. it wont really affect how the car runs, its just there to clean the exhaust gases. the second sensor in the cat tells the ecu if its working properly. does not affect performance.
Old Oct 10, 2009
DjExotic's Avatar
then how come when i try to punch it on the highway it lagging to get up to speed.
Old Oct 10, 2009
could be a combination of things. maybe just needs a tuneup. and the car isnt fast to begin with.
Old Oct 10, 2009
ronaldo9's Avatar
Make sure you are not in limp mode for whatever reason. FYI you will run a bit leaner w/o the cat.
Old Oct 10, 2009
DjExotic's Avatar
well, i going to put the cat in and the 02 with it come in the shop and going to do the tune up since it have 138k.
docmartin14
Jul 30, 2015 11:26 AM
dbagaus
Jun 10, 2015 09:29 AM
kevin99ek
Apr 23, 2015 09:32 PM
Cilvic
Dec 28, 2001 07:49 PM
SOHCScreamer
Dec 21, 2001 10:10 PM
