B16a2 Valve Cover & Vtec Controller
Old Sep 30, 2009
civicsi40's Avatar
civicsi40 is an unknown quantity at this point
Thumbs up B16a2 Valve Cover & Vtec Controller
whats up i just had a few questions, does anyone know how and the right way to replace the valve cover? and what torque the bolts need to be set at
and also i was wondering if anyone knew how to hook up a vtec controller?
Old Sep 30, 2009
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Re: B16a2 Valve Cover & Vtec Controller
Torque specs on valve cover bolts: 7.2 ft/lbs. Be sure to do it in sequence as well.
Old Sep 30, 2009
TRIZ's Avatar
As for the vtec controller, follow the instructs for splicing the wires into the wires headed to your ECU, or tap them.. if you dont want to do that, as I didnt, buy a harness which allows you to connect the vtec controller to your ECU with out any modifications to your wire harness.
If you have an 01-05 civic and an Apexi Vafc2 controller, then go to dezod.com and buy the harness.
Supramk3
May 11, 2015 07:55 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bambuski
Dec 16, 2001 05:57 PM
CivicPunker17
Dec 1, 2001 06:58 PM
