how to put back a distributor back into the car
Old Aug 22, 2009
ProVic's Avatar
ProVic is an unknown quantity at this point
how? im stuck, i think i crack something
Old Aug 22, 2009
ilikesnackpacks's Avatar
ilikesnackpacks is an unknown quantity at this point
Re: how to put back a distributor back into the car
Hike it up to O'Reilly's or AutoZone and buy a Haynes manual. I'm just being a smart *** because I don't know, and I'm actually kind of interested.
Old Aug 22, 2009
so you took it off? i think it goes back the same way but then you have to set the ignition timing again.
Old Aug 22, 2009
ProVic's Avatar
okay, i took out the distributor. remove all the wires and 3 bolts. I wanted to see if it was the cause of my leaks. when i remove it....all the past oil was under it....maybe its because an o-ring. maybe....but darn it!!!! i crack something when i was putting it back on. At the moment I didnt know how to put the distributor back then one thing led to another, the very top of where you can screw(out of three) back(part of the engine) cracked. its a pretty big crack now. I think it is replaceable. but the frame has a crack. The circle where you put back the distributor. I just need to know where i can find that part. here is the picture...it is the part you screw back on. i am worried if the car is not drivable because of that crack. What do you think? is it safe? Now im sure the leak is slowly coming from there now because of me. I feel dumb. fml
Old Aug 22, 2009
yeah i think that will leak if its cracked. they sell the cap and rotor separate but thats it. if you cracked the housing, you gotta buy a new distributor
Old Aug 22, 2009
ProVic's Avatar
the distributor/rotor/cap are fine. its the place where you connect it from is cracked
Old Aug 23, 2009
pics? you mean on the engine?
Old Aug 23, 2009
ProVic's Avatar
in the red circle....right next to the distributor...really hard to see
Old Aug 23, 2009
i think thats part of the valve cover which isnt too hard to replace. they are pretty cheap too if you look for used parts on ebay or junkyard.
Old Aug 23, 2009
ProVic's Avatar
its part of the cam shaft
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
BREADFAN
Apr 15, 2015 08:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
