1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1994 Civic Wont start and overheats!
Old Aug 7, 2009
troberts289's Avatar
troberts289 is an unknown quantity at this point
Hello. So I have this civic. Its a 1.5 liter single overhead cam. I am having problems with it. It all started with it overheating. I jumped the fan so It would stay on constantly, and changed the the T-stat and temp sensor. Still overheated. Later I got to start it and the battery was dead, So i jumped it, and started right up. Then go to shut it off and it didnt start again, Just kept ctranking. Im prety sure the coil went bad on it. Im going to try the externam coil mod on it to make life easier. But the overheating thing is the real issue. After it didnt start I did a compression test on it. Compression was great. I pulled the distributor off to test the ignitor. I got a new one. Still didnt start. But the i noticed that it turned over really easy. Did another compression test on it and i hardly had anything!!! And from the time i tested it the first time until now It wasnt running. All i did was pull the distributor off!! I did a leakdown and it seemed like air was leaking through other cylinders, like pressure comming out the plug hole on the companion cylinder... What is going on here??? Did the head gasket blow or was about to and just let go without even running? bad waterpump? Rad clogged I have no clue! Any help would be great, I just dont get this at all.
Thanks, Tyler
Old Sep 12, 2009
wingnutCcoupe's Avatar
wingnutCcoupe is an unknown quantity at this point
Re: 1994 Civic Wont start and overheats!
yeah, i know how u feal. i started looking around and i seen ur post. im having tha same prob on my 95 coupe. i took tha distrid all apart tested everything and its showing to b good. did u ever find out what was wrong on yours. please let me know. my email is wingnutcivic4dr@yahoo.com and my im screen name is tha same for yahooplease help
Old Sep 12, 2009
when you pulled the distributor off, did you set the ignition timing?
Old Sep 12, 2009
NO, what do i got to do
Old Oct 27, 2009
kycivic's Avatar
kycivic is an unknown quantity at this point
im having a similar problem on my 94 ex. i changed the intake gasket and when i did it got coolant in the number 4 cyclinder. fixed all that then plugs weren't firing. replaced plugs, coil, rotor, cap, and wires. now its getting spark but it wont start. when it cranks the engine jumps. sounds like we have a common problem
Old Oct 27, 2009
sounds like timing issues (cam or ignition). maybe something got messed up.
Old Oct 27, 2009
kycivic's Avatar
maybe it did. could ya explain how to check/adjust either
Old Oct 27, 2009
well ignition timing i think you need the timing gun and you shoot it in the hole near the trans case where the belt is turning. i really have no idea to be honest, my car doesnt use distributor. cam timing you check by making sure all the marks like up on the cam gear and crank pulley. its pretty complicated and you prolly need a repair manual.
Old Oct 27, 2009
BlueEM2's Avatar
Whachya lookin at?
Take it to a shop and get them to do it... You need special tools and it's a special procedure designated for special people... I had a 1992 honda accord with an H22A and I pulled the distributer without lining it up with marker and the same thing happened. Because of it I lost compression in 2 cylinders...
Old Oct 28, 2009
our 92 accord was very lucky, the distributor melted and it threw the timing off by about 20 degrees. engine would start, but would feel like nothing is happening when you gas it. thankfully the engine was perfectly fine once they timed it.
Old Oct 28, 2009
BlueEM2's Avatar
Whachya lookin at?
yea gearbox i did the same thing except i screwed the engine unfortunatly... luck you that everything is okay.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
