HELP! Squeaking noise coming from driver side wheel area.
Old Aug 5, 2009
mdn217's Avatar
mdn217 is an unknown quantity at this point
I was coming home from the store earlier today and my car began to make a high pitched squeaking noise. it sounded as if it was coming from the front drivers side wheel area.(The noise was only there when the car was moving..) After i got home, i noticed that the front drivers side wheel was very hot, a lot hotter than the others. and there was an odor coming from that side.(almost like a metal on metal smell?) If anyone could give me any possible solutions to this problem or at least diagnose it i'd really appreciate it...
Thanks
Old Aug 5, 2009
04 Honda Civic's Avatar
Re: HELP! Squeaking noise coming from driver side wheel area.
Dust sheild? Rotor? Bad bearing maybe? It could be almost anything take it off and take a look in there it should be really apparent on what it is.
Old Aug 5, 2009
mdn217's Avatar
I made sure the dust shield wasnt rubbing. I even bent it away even more and the noise is still there... how can i tell if the rotor or bearing is bad?
Old Aug 5, 2009
kcari's Avatar
if your rotor is bad then when u brake u might feel pulsation in the pedal You might also hear noise. a bearing is bad if you jack the car up, give the wheel a spin and still hear the noise- plus ur wheel might be wobbly too. maybe new brake pads?
Old Aug 6, 2009
mdn217's Avatar
i think i found the problem...brake pads. the pad is not even visible in the caliper on the drivers side...im guessing the pad is shot. i am going to replace them tomorrow and see if that solves the problem. Any recommendations on break pads?
Thanks for the replies
Old Aug 6, 2009
kcari's Avatar
ceramic pads are nice. but oem is just fine
Old Aug 6, 2009
OEM is good. Make sure your rotors are smooth before replacing the pads or it will sqeak down the line and probably be crappy braking.
Old Aug 6, 2009
mdn217's Avatar
caliper was froze....
Old Aug 8, 2009
ouch..grease and clean your slidepins every time you do your brakes.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
civicns
May 8, 2015 09:49 PM
dennis123
May 3, 2015 03:14 PM
ej8
Apr 13, 2015 06:36 PM
tattedlariat
Apr 12, 2015 07:55 PM
