1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Civic 90 Sedan Mirror
Old Jul 5, 2009
canolapole's Avatar
canolapole is an unknown quantity at this point
Hi everyone! My first message here about a Civic that doesn't have an opening or anything at all for a passenger side mirror (*photo attachment*). My question is - how do I fit in a mirror there? Do I need to bore a hole in the two triangular block plates? That seems so cumbersome!! Please let me know if there is a way to get a mirror there.
Old Jul 5, 2009
CraigW's Avatar
Re: Civic 90 Sedan Mirror
Have you had the inside trim loose yet ??
If the metal has the holes already present... you would have the perfect template to drill them for a factory mirror.
Old Jul 5, 2009
canolapole's Avatar
Thanks for the reply. Did you mean the inside (window facing side) of the triangular block plate thats inside the car? If you did: no, I haven;t been able to do that. I took the panel off the door and tried to pull that blcok plate away but its very tightly held there, and I can't see any screws or anything.
Old Jul 5, 2009
CraigW's Avatar
Not sure how cover is held in place, Maybe you could pull edge back and look for mounting holes with flashlight.
Old Jul 9, 2009
canolapole's Avatar
Worked Had to grit my teeth and yank the plate off. It did NOT break, as I feared and didn't want to do put a lot of force. Now comes the part of finding a cheap mirrir
vtec92
May 4, 2017 03:20 AM
usajags84
May 10, 2015 08:11 AM
aus10
Apr 13, 2015 09:26 PM
Lightman
Nov 10, 2001 06:44 PM
Crash2002
Oct 26, 2001 05:02 PM
