ES Bushings or new control arms for cheap?
Whachya lookin at?
I'm kinda torn!!! I have two choicces!
1. Buy lower control arms for 80 dollars each (Canadian) that include the bushing and ball joint from a friend at work. (Brand new, he gets shop rate)
2. Order ES bushings and never worry about it again. It will be more work for me to install ES bushings than to just slap new control arms on.
I don't really NEED new bushings yet at 85K miles, but he can get me the arms for cheap so I was just wondering on what I should do, hold off for ES or buy the new arms.
Re: ES Bushings or new control arms for cheap?
My bushings were going at 55k and I replaced them with the ES as well. I would recomend them over the other option however be ready for some noise because they are squeaky squeaky.
Just let you know the shipping cost to canada is nuts.....
I ordered the motor mount inserts and the lower control arms bushings since they are both torn....paid 120CAD after shipping.
Btw, I don't have a press....so i have no idea how to install it.
Remove control arms, press old ones out, press new ones in, reinstall control arms.
If you know how to turn a wrench the hardest part is pressing in/out the bushings. You can take it to a shop- machine shop probably, or do it yourself. I cant find the thread where a guy made his own press. He basically has two pieces of wood and four bolts through the corners with wing nuts on the end. He'd twist each one a quarter of a turn repeatedly alternating between the four corners and press it out/in. You obviously need to have a little chunk of something to press against the bushings that will push it out and a place for the old bushings to go when removing it. Get it? Kinda hard to explain.
Whachya lookin at?
120 CAD is not all that bad really... and I have a friend who is a mechanic and will press them out/in if i bring in the control arms.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
OptimisticWay
46
Oct 15, 2015 02:16 PM
califcamper
Jul 21, 2015 10:34 PM
fordover
Jul 11, 2015 09:10 PM
