Steering Wheel Shaking
Old Jun 27, 2009
Newjd2's Avatar
Newjd2 is an unknown quantity at this point
I've brought my car to Honda and a Meineke and neither place can figure it out. My steering wheel shakes, but only after the car heats up. It isn't any of my motor mounts because they've all been checked. It only does it when I'm stopped at a light or something. I don't have any idea what it is so if anyone has any ideas I'd appreciate it.
Old Jun 27, 2009
kcari's Avatar
Re: Steering Wheel Shaking
bushings? power steering fluid levels? axles in the front? something's bent?
Old Jun 27, 2009
BlueEM2's Avatar
Whachya lookin at?
Is it related to a rough idle??? Clean your throttle body sensors and such and such. That might help. Does the car feel like it wants to stall?
Old Jun 28, 2009
Newjd2's Avatar
No, not at all. The car is quiet except the steering wheel shakes/ vibrates which in turn my exhaust will move somewhat causing some sounds, but the annoying part is just the steering wheel shaking. I'm stumped. If it helps I have an aem short ram intake, but I don't see that affecting my throttle body.
Old Jun 28, 2009
lordhelmet's Avatar
Does it shake when your sitting still or moving?
Old Jun 28, 2009
BlueEM2's Avatar
Whachya lookin at?
The only thing I can think of is what you have already covered which is motor mounts. or Idle which is probably not the problem. Hmmm. Have your transmission checked? Is it auto or manual?
Old Jun 29, 2009
Newjd2's Avatar
I have a manual...and it's only when I'm stopped at a light...Doesn't seem to be shaking at all while driving...I appreciate all the help...I'm just as stumped....I might have the motor mounts checked out again...You never know...
Old Jun 29, 2009
TRIZ's Avatar
Does it happen all the time when stopped, or just when the fan kicks on?
Old Jun 29, 2009
Newjd2's Avatar
both....after booting up the car a couple minutes later it will start the shaking...from 3-5 minutes after ignition all the way up to turning off the car....it happens whenever I'm stopped...
Old Jun 29, 2009
BlueEM2's Avatar
Whachya lookin at?
It's not likely for a manual transmission to cause this, I'd check the mounts yourself. Just start the car and rev it from the throttle body. Check to see if you can hear anything and see how much movement the engine has. The 7th gen civic has a mount that has a high wear rate that you might want to look into as well. It's posted all over the forum here.
Old Jun 29, 2009
im sure its a low idle issue causing the engine to shake and you feel it in the steering wheel. clean the intake system and throttle body sensors.
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
