Install Weapon-R intake?
Old Jun 25, 2009
zeusx99's Avatar
zeusx99 is an unknown quantity at this point
Kinda new and the guide that came with it is absolutely useless...
Searched google, the site and the forums for a DIY for about half an hour to no avail. Anyone have something that would be of help? Would reallllly appreciate it
Old Jun 25, 2009
MidnightCivic's Avatar
Re: Install Weapon-R intake?
https://www.civicforums.com/forums/7...gging-fix.html
Gearbox should chime in on this
Old Jun 25, 2009
zeusx99's Avatar
Thanks, the pictures really help. I was more confused because procivic sent me a free ram kit, and so I had no idea what went where. Got it all figured out.
New problem though. After installing everything and making sure that it's all secure, I turned on the car to let it idle for a bit. After a couple of minutes though, I started hearing this squeaking noise. I'm assuming that that's not really normal....
Edit: CEL is running, though I don't know why. I replaced the MAF sensor exactly as it should have been.
Old Jun 26, 2009
I have no clue...also i believe you need to unplug your battery for a few minutes after you install the intake..ill bump the thread for gearbox
Old Jun 26, 2009
m3gach33zy's Avatar
Delightfully tacky. Yet unrefined
m3gach33zy is an unknown quantity at this point
I havent installed the weapon intake but you have to unplug the battery to install it then plug it back in after install is finished
Old Jun 26, 2009
im guessing this is on an 06+ civic. maf sensor intakes are tricky, make sure there are no air leaks. most aftermarket intakes seem to cause problems with the sensor. but try pulling the battery and reset the ecu, if everything clears up, it should be fine.
Misfit2613
Jul 30, 2015 09:49 AM
hoofboy
Jul 17, 2015 04:27 PM
NoobyKid
Jul 13, 2015 07:53 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
