1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 EX Z6 civic missing ect....
Old Jun 24, 2009
Vitamens's Avatar
Vitamens is an unknown quantity at this point
Need help here guys... pretty car illiterate.. can do the basics but im stumped here... So the car is missing in every gear.. its lost power in every gear and the idle has went down from one to bout half a grand.. The missing is worse when its cold then warm but still pretty bad warm.. The worst time it misses is the more gas you give it.. if you ease into the gas it might initially miss a lil but it will pick up and slowly gain RPMS.. but it won't turn the rpms anything like it should.. If you have the car parked and give it gas it will twist the RPMS like normal but when it gets the load on it--it then starts to miss and sputter.. At about 1/8 of throttle it seems to do normal but if you give more then that MOST of the time it will kinda cut out and sputter and BARELY BARELY gain speed (better to just go back to 1/8 of the throttle). But to speak about the MOST.. sometimes you can give it about 1/2 throttle and it wont sputter out but the power still isn't there (doesn't climb in the RPM's like it should)... Also more info when you are giving it gas (going to the 1/8 of the throttle point) it will sputter just enough to notice then goes back to the pull.. but if you try and go about 1/4 throttle or more it will sputter and miss.
So i know its alot but any suggestions would be nice..
Like i said about plugs and wires have been replaced--ready to go from there.. i suppose distributor cap and button are next in line but if anyone has delt wit this and fixed it.. your input would be nice.. thank you.
Old Jul 27, 2009
94honciv's Avatar
94honciv is an unknown quantity at this point
Re: 94 EX Z6 civic missing ect....
Yea,try rotor and cap if you have already changed plugs and wires.Check vacume lines for cracks,check all your electrical plugs.could be bad gas.How long has it been doing this?Might be a cat.converter.Just a few things I would check out.Check back and let us know.Good luck,Mike
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
cooldan1
Apr 23, 2015 10:49 AM
Jonas Powell
Apr 16, 2015 11:47 AM
BREADFAN
Apr 15, 2015 08:58 AM
usajags84
Apr 10, 2015 09:54 PM
