8th Gen 2006 - 2011.
Rotated tires-Worn pretty evenly
Old Jun 15, 2009
krazymatt's Avatar
krazymatt is an unknown quantity at this point
I rotated my tires this weekend after 14k miles. I know I should've done it sooner but I've never rotated tires on a vehicle with that many miles and found them as evenly worn as I found mine. I must say they are pretty much dead even on wear fronts vs. backs. With that said I had already noticed my back tires being noisy, now they're on front. Not normal road noise but almost like a out of round road noise. It must be the fact that they are the crappy Bridgestones? I've had that same noise problem with other Bridgestones in the past on a different vehicle.
Old Jun 15, 2009
CraigW's Avatar
Re: Rotated tires-Worn pretty evenly
They may be scalloped ??
I rotate mine at 5k some do at 10k.
Once they get noisey they will stay that way until the end.
Old Jun 15, 2009
Jp7's Avatar
Jp7
Jp7 is an unknown quantity at this point
I rotate every 3000 miles.
Old Jun 15, 2009
rocksinger45's Avatar
rocksinger45 is an unknown quantity at this point
I did mine @ 15 g's and saw the same wear as you with no noticeable noise. Go Figure !!
Old Jun 15, 2009
krazymatt's Avatar
They probably are slightly scalloped due to lack of rotation. Oh well, I should've done it at 10k. I'll just live with it till at least 30k. It's really not all that bad. I notice it more at freeway speeds. It only started about 500 miles ago.
Old Jun 15, 2009
it happens, depends on the tire and other factors. alot of people never rotate their tires and still get alot of life out of em.
Old Jun 15, 2009
Jp7's Avatar
Jp7
Mines the same way but I can't hear it anyways with open wastegate, test pipe, big cams & stronger valvetrain.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mattdoc
Mar 14, 2017 12:10 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
thesushiboy
Jun 15, 2015 12:21 AM
locozoko
Nov 4, 2001 05:45 PM
