2002 Honda Civic - ignition switch hard to turn
Old Jun 13, 2009
OldCivic's Avatar
OldCivic is an unknown quantity at this point
Unhappy 2002 Honda Civic - ignition switch hard to turn
The ignition switch on my 2002 Honda Civic is hard to turn from the OFF --> On --> Start position. Shaking the streering wheel does not seem to be a factor. Turning the ignition switch from ON --> OFF after driving the car is normal, no resistance or extra force is required. So far no electrical problems, other than the SRS light came on about a week, not sure if it is related or not. It sounds like the key cylinder is going bad I guess. Has anyone heard of or experienced this?
Old Jun 13, 2009
cosmicmeltdown's Avatar
cosmicmeltdown is an unknown quantity at this point
Re: 2002 Honda Civic - ignition switch hard to turn
jiggle, jiggle... thats my suggestion unless it is so bad that you can't ever turn it over. in that case you need to replace the the tumbler (ignition switch). my 99 si has trouble turning over when it is really cold out (less then 32 degrees). i usually have to sit there for a few minutes jiggling the key and turning the steering wheel until it hits the sweet spot. the SRS light i believe has something to do with air bags. does it stay on all the time? if so i would go talk to a honda mechanic. my SRS comes on when the ignition is on for 15 seconds or something like that and then turns off automatically. good luck man!
Old Jun 14, 2009
spray some compressed air, maybe there is some junk inside. then spray silicone lube and try again. usually they just get stuck and need lube.
Old Jun 14, 2009
OldCivic's Avatar
Unhappy Re: 2002 Honda Civic - ignition switch hard to turn
Thanks for the quick reply.
Do you know if there is any mechanical linkage going from the shifter (console / automatic) to the ignition switch tumbler? I believe its electrical switches to keep the vehicle from starting when not in PARK but I am not sure. If it is electrical then we are back to possible replacing the tumbler.
I agree, the SRS (air bag light) will have to be looked at by the dealer.
I will try the compressed air then apply a small amount of dry graphite powder or spray with a small white lithium grease.
Old Jun 14, 2009
yeah the shifter lockout is electrical. use silicone spray, i have used graphite and pb blast and it just made a mess. and then your key will constantly be covered in gunk when you take it out. silicone spray dries and only the lube stays on the parts. no liquid or powder to get everywhere.
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
tkcne
Apr 18, 2015 02:33 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
vino
Nov 3, 2001 11:08 PM
