buying new rims what do i need
Old Jun 10, 2009
Rastaman_bob's Avatar
Rastaman_bob is an unknown quantity at this point
hey guys,
i am planning on buying some 16' rims what do i need to take in consideration in doing this. do i need to buy shocks to support that type?, change the springs or just cut it?. i notice that the wheels are camber already not sure if its factory default.
n.b i should mention that it is pre owned, factory rims with honda hub cap and it's a 02 civic exi
Old Jun 10, 2009
TRIZ's Avatar
Re: buying new rims what do i need
The suspension components are going to be fine, you can run aftermarket rims on stock shocks/springs with no issue whatsoever. To fix any camber, you need a camber kit. When buying rims, make sure the width you get will fit inside your wheel well and not rub. Other then that, make sure the offset will clear all the brake components and all that jazz. And of course 4x100 bolt pattern.
Old Jun 11, 2009
thanks man
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
srtlat
Jul 17, 2015 11:53 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
