1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 civic dx hatch won't start
Old Jun 4, 2009
zonk's Avatar
zonk is an unknown quantity at this point
hi, I have a 92 dx hatch with a d15b7,the car has been sitting a year since I have been in Iraq and I just returned home to find it won't start. yesterday I replaced the fuel relay, and the fuel pump after turning the ignition and not hearing the fuel pump kick on but I am still not getting any fuel to the motor,tested the spark and I don't have any. the motor turns over fine, I have trouble shot it to the best of my knowledge, according to my neighbor I need to check the ignition control module or the ecm. I was wondering if anyone had a illustration as to wher ei might find the ICM, I have a suspicion it is somehwere around the distributor but I have never fooled with one good enough to take it apart to find it. than ks for you guys help
Old Jun 6, 2009
zonk's Avatar
Re: 92 civic dx hatch won't start
narrowed it down tot he #6 pin on the fuel relay wiring harness...now what that is, and how to fix it I have no idea
edit: no power is reaching the distributor and all fuses check out
Old Jun 7, 2009
matthew7982's Avatar
matthew7982 is an unknown quantity at this point
first of all, welcome back. Did you check the main relay under the dash? pin 6 should be the batt. voltage.
Old Jun 7, 2009
also, i believe the ICM is located underneath the distributor cap (looking at the Haynes Manual for it, cause i have a 92 civic ex sedan). It seems like your problem is basically somewhere in the distributor maybe?
Old Jun 16, 2009
zonk's Avatar
checked the water pump ground, pin 6 has no power going to it, replaced the distributor . while checking I replaced the plugs, fuel filter, and plug wires. still not getting any spark or power to the fuel pump. only lights that are working on the dash are the battery and srs light.
Old Jul 23, 2009
zonk's Avatar
turned out to be a bad computer...was actually trying to sell the car on craigslist and he came to buy it....turns out he fixed it for a fifth of crown
Braun
Apr 23, 2015 09:03 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
