"Vibrant Strut Bar"?
So I found what looks to be a pretty good deal on a somewhat no-name strut bar on autopartsway.ca (http://www.autopartsway.ca/acp/index...SC568~PT632248)
Just wondering if the brand really makes a huge difference, or if a somewhat no-name brand (like this one) will do fine as well.
Thanks.
Thanks.
Re: "Vibrant Strut Bar"?
couldn't you just take it out and put it back in if you want to clear an aftermarket intake? seems pretty easy, like just screw on/off some screws.
i've heard neuspeed ones are the best because they don't get in the way of anything in our civics. is this true? it's also so hard to find neuspeed bars :/
Well sure you could take it out if you were running an intake, but the idea is to be able to run both the intake and the strut bar. You can run that bar if you do a couple things.
Rotate the bar forward and use a hacksaw to trim a little bit off the intake pipe so it sits lower.
Like so:
Like so:
