2006 Civic sunroof issue
First time poster...so if this isn't in the right spot, any help on the right forum on this site would be appreciated.
The automatic front and back functions on the sunroof don't work anymore. I used to be able to press once straight up in to the toggle switch, and it would automatically move to the position where it tilts forward and lets air in the back of the opening. The same single press would close it to the closed position. That no longer works. I now have to press and hold.
I also could just press once back on the toggle and release for the sunroof to slide entirely open or closed...just like my driver side window. That functionality of the sunroof stopped working as well.
What this means is that I am having to guess if I have it completely closed when I move back and forth between the tilt position and the open position. It used to just automatically set itself.
Any suggestions? Is this something I can reprogram? I fuse issue? Or do I need a larger repair? Many thanks for any help.
Re: 2006 Civic sunroof issue
For the "auto" feature on the drivers side window to work after the battery is disconnected you must reset it.
Maybe it is a similar situation with your roof requiring a process to 1st be done ???
Xuhme
21
Aug 7, 2023 03:40 PM
