Sticky accelerator
Old Apr 27, 2009
rponycar's Avatar
rponycar is an unknown quantity at this point
Sticky accelerator
The accelerator pedal on my 97 lx is hard to press and then gives way all at once. Makes it hard to pull away smoothly. I've hit all the pivot points w/ WD-40, at the pedals and under the hood. Anyone had success fixing this? I'm hoping I don't have to replace the cable.
Thanks
r
Old Apr 27, 2009
Re: Sticky accelerator
disconnect the cable from the pedal. does the pedal still stick? if so you just have to lube it some more. if not, its prolly the cable or you can also spray the throttle body assembly where the cable is. maybe its just gunked up.
Old Apr 27, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
I agree with Gearbox...and am guessing that the cable has been bent once. A new one is only $17.11USD full retail at a dealer.
Old Apr 29, 2009
not4plato's Avatar
not4plato is an unknown quantity at this point
Try cleaning your throttle body before you pay for any replacement parts.
Here is a story about a sticky one and how to clean it.
http://jasongraphix.com/journal/gas-pedal-sticking/
That's about a Camry.
Here is an article on Honda throttle body cleaning. Its easy and cheap and throttle bodies can cause the symptom you describe.
http://www.hondaclub.com/forum/artic...-cleaning.html
Bruce2
Sep 27, 2015 08:45 PM
tropicola
Sep 25, 2015 07:02 PM
charmon4815
General
Sep 22, 2015 08:00 AM
dantheman42
Sep 4, 2015 01:10 PM
