2003 civic EX Engine sputtering in idle with Check Engine Light
Old Apr 24, 2009
pcheruka's Avatar
pcheruka is an unknown quantity at this point
Code shows p0300, p0301, p0302, p0303, and p0304,
Random misfiring of all cylinders
67000 miles, Any suggestions as to where to start?
Old Apr 24, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: 2003 civic EX Engine sputtering in idle with Check Engine Light
check if the spark plugs have a spark.
Old Apr 25, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
They have to be getting spark since he can start the car. It sounds like ignition though. I would check the cap and rotor for any severe wear or cracks. Also test the igniter as well since it's possible that it is not giving off enough spark per cylinder.
Also the timing may be bad and the spark is coming so late the engine is reading it as a misfire. If any work was done to it right before it happened or if you were in an accident, I would check everything that was touched. If you can remember what happened right before the CEL came on, that'd be a lot more helpful
Old May 5, 2009
Drakus's Avatar
Drakus is an unknown quantity at this point
Just had the same problem with my car.
My problem was the MAP sensor. I have a 00 auto
Not sure where your MAP would be located but mine was right behind the throttle body.
Hope this helps.
Feel free to ask if about anything
Xuhme
21
Aug 7, 2023 03:40 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
