Car Clock flashing, won't reset after battery change
Old Mar 19, 2009
ksymak's Avatar
ksymak is an unknown quantity at this point
Ok, Here's what happened:
My car went in for some repairs. During repairs I guess my battery died and had to be recharged. Of course in the process my factory radio went into auto-theft mode and needed to be reset with the radio code.
Ok. So I got the radio code, Had to disconnect the negative pole of the battery because apparently the maximum tries to enter had been reached. Reconnected the battery, entered the code, radio is working fine, but my clock keeps flashing and won't set even when I follow the procedure to set it.
I don't know if this has anything to do with it, but my SRS light that usually just flashes for about 5 sec when I start the car, now stays for about 20 sec longer than usual, then turns off.
I have a 2002 Civic. Any Honda techs on here that can help me? The clock thing is bugging me because I thought getting the CODE was the difficult part, and now this.
Much appreciated.
Old Mar 19, 2009
Re: Car Clock flashing, won't reset after battery change
hmm never heard of that. sounds like a problem with the radio tho. maybe it got damaged.
Old Jun 13, 2009
pinkers's Avatar
pinkers is an unknown quantity at this point
I'm having the same problem! Please, doesn anyone have any idea how to reset the clock? It's driving me nuts!
Old Jun 13, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
I would try disconnecting the radio for about an hour and see if that will reset the head unit. As for the airbag light, i the SRS computer maybe taking longer than usual to read its internal data. Was the car jump started?
Old Jun 13, 2009
silver25civic's Avatar
silver25civic is an unknown quantity at this point
if you stayed close to me i have a stock 04 and 05 civic ex radios.i have my books when i bought my car but they are in it and while im off of work im trying to be lazy.ill go see about it later today it is like over 90 degrees today its hott. my airbag light stays on too but it could be caused by the truck that hit me from behind at a red light a couple of years ago. it did little damage mostly to the trunk. did you ever have a fender bender?
Old Jul 2, 2009
woody2shoes's Avatar
woody2shoes is an unknown quantity at this point
2002 Civic EX
Similar problem here! After changing battery, the "code" letters display when I turn the radio on. IF I push any of the buttons for selected stations, I get an error code 1,2,3,4,5,6,7,8,9, and/or ERRE. Radio/CD does NOT work. I read in manual it takes a "few days" for things to reset after changing the batter, but it has now been about 4 weeks.
What gives? any help is appreciated.
Old Jul 2, 2009
CraigW's Avatar
It is wanting the anti-theft code entry.
Look in your glove box for a white tag. Or with the owners manual and paperwork.
Old Jul 5, 2009
Smile Re: Car Clock flashing, won't reset after battery change
THANKS BUNCHES... WILL GIVE IT A TRY. But, IF I find white tag how do I enter the code? Guess I will find out!
NOPE, did NOT find the white tag mentioned or any indication of a sticker that might have been removed in the past. Manual has no info either.
SURELY there is a way to get the "code" to enter???
Last edited by woody2shoes; Jul 5, 2009 at 09:00 PM. Reason: After checking for white tag presence.
Old Jul 6, 2009
CraigW's Avatar
The dealer can get the code... You need the radio's serial #s. IIRC they can be displayed on the unit.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
jstotts
Apr 20, 2015 09:32 PM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
