ventilation - NEED HELP ASP
Old Mar 2, 2009
316's Avatar
316
316 is an unknown quantity at this point
Hi
Last night I opened the dashboard to get to the headunit, by mistake my phone somehow went inside the ventilation hole, the once at the front of the car in the middle. I tried to put my hand through but the hole was too small and tight.
Is there a way to get to the phone?? I tried everything but nothing worked. NEED HELP ASAP, because I am scared that the phone might explode inside the ventilation because hot air comes from there.
Thanks in advanced
ID:	75856   Click image for larger version
Old Mar 2, 2009
speedfoos's Avatar
Re: ventilation - NEED HELP ASP
It won't explode, but you're going to have to pull the dash off to get to the climate control unit to get it out though.
Old Mar 2, 2009
316's Avatar
316
I did remove the dash panel, thats how it got in there in the first place, lolls.
After removing the dash panel, whats next??
Old Mar 2, 2009
04 Honda Civic's Avatar
hmm I wonder if it could burst..those temps can get up to like 160* F or more
Old Mar 2, 2009
skipbarber's Avatar
why does everyone think that all electronic devices explode when exposed to heat? it's a phone, not a IED. you should be able to remove the blower motor from behind the glove box and that should give you access to the vents. Otherwise speedfoos is right, you're going to have to pull the rest of the dash out to get the vents all out. I think you misunderstood his post, obviously you took the dash trim out, he's talking about the entire dashboard.
Old Mar 2, 2009
speedfoos's Avatar
Yep. The whole ***. Not just half of it.
Old Mar 2, 2009
lol I dont think it will explode haha..but the battery could burst from the high heat.. which may not be too good
Old Mar 2, 2009
forget it its gone lol. just get a new phone and move on. you might try to reach from the bottom middle section where the console ends, maybe it fell straight down and you got lucky.
Old Mar 3, 2009
316's Avatar
316
Thanks everyone for the replies, i will try to check underneath where the console ends, and see if it fell out. I did not reliease that there is a gap at the end of the console. Otherwise i will try to remove the whole dashboard panel.
Thanks everyone, keep the ideas coming though...
Old Mar 3, 2009
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I sure as hell wouldn’t leave it. Some of you guys should read more on LiPo battery failures. Even though the ones on phones have safety circuits I wouldn’t want it getting that hot. I run LiPos in my RC cars and have had a one go up in flames along with the (rc) car it was in.
Old Mar 3, 2009
skipbarber's Avatar
Ive had an RC go up in flames with a NiCD. the heat in a cars ventilation system wouldnt reach the temp required to ignite a LiPo.
Old Mar 3, 2009
dopes6070's Avatar
LOL either way I wouldnt want it in there...
Old Mar 3, 2009
CiViCPrAnInG2k1's Avatar
make sure u have video running so when it explodes u catch it on camera. LULS...
Old Mar 3, 2009
speedfoos's Avatar
RJ you're a ****ing idiot. Go play in traffic.
Old Mar 3, 2009
dopes6070's Avatar
Lol...
Old Mar 3, 2009
i once left my old gameboy in the car all day where the temps were over 150F in the car. when i saw it the screen was a different color lol. but everything worked fine once it cooled down. just try not to use the heater that much with the phone in there.
Old Mar 3, 2009
lawls.. u want me to die?
Old Mar 3, 2009
good assumption ^^
Old Mar 3, 2009
TemjinX2's Avatar
lol...i really doubt it. I ran my old amd 1ghz cpu over clocked to 1.4ghz running at 160 F for 3yrs and it ran fine. Didnt even freeze. So i doubt the battery would explode from just 160 degrees.
Old Mar 3, 2009
I dont know cpus are made to take high heat, batteries are not.. I wouldnt speculate about this personally.. I would rip my dash apart to get at it.
Old Mar 4, 2009
TemjinX2's Avatar
lithium ion batteries only catch fire from overcharging or manufacturer defects. Those were with older laptop batteries not cell phone batteries which tend to be more advance then there laptop counter parts.
http://computer.howstuffworks.com/dell-battery-fire.htm
i think your over exaggerating the danger. In 5 days the phone will probably be compelety out of charge anyways.
Old Mar 4, 2009
TemjinX2's Avatar
think about it...if lithium ion batteries can catch on fire or explode that easily...you would be able to blow up tesla's with a $10 heat gun....that can go up to 500 degrees F...
Old Mar 4, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
My friends Li-ion cell phone battery lit his whole rooms carpet on fire....but i assume stabbing the battery with a knife didn't help the carpet not ignite.
Old Mar 4, 2009
TemjinX2's Avatar
well i hope your friend acts a little more wisely or darwinism will get the best of him.
Old Mar 4, 2009
manahoonie's Avatar
does the bottom section have tubes that go down beneath the front seats to blow air to the rear seats? are you able to shine a light down there and see the phone at all?
honda.lioness
Aug 23, 2015 10:10 AM
Whirlwind
May 20, 2002 12:51 PM
Nj
May 9, 2002 08:30 PM
JoeB16
Feb 17, 2002 07:08 PM
CivicVTec
Feb 7, 2002 08:12 AM
