02 rsx-s brakes on 01 civic
i paid 1000.00 bucks for all the suspension, brake system, sway-bars, rims+tires, lower control arms, and trailing arms. im getting the motor to but in a month or two so my qestion is are the half shafts different? i have been told that they are but i would like more than one input
I wil fix vBPlaza today
Re: 02 rsx-s brakes on 01 civic
did you want to install the suspension before the motor? i would advice you to just wait it out. You will need the half shaft from the type S motor anyways when u swap.
might as well as do it all at once
ok ya i am getting the motor and all the parts and motor are all from the same car my buddy is helping me out and holding the motor and everything that is coming with it, and the type-s half-shafts came with all the suspension parts. ok so the type-s half-shafts wont fit into my 1.7L tranny? and ya i did want to do the 5 lug swap befor the motor swap just to do it, it would give m something to do over the weekend hahaha but if i should wat i can. it wont be long for me to get the motor anyways
You should just wait since you will need the type s axles but if you had the base rsx brakes they would bolt right up and u can just change the calipers & rotors for the type s ones
Try searching more this topis has been covered many times.
Xuhme
21
Aug 7, 2023 03:40 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
