i need help with foglight harness!!
Old Jan 7, 2009
TOEnail's Avatar
TOEnail is a jewel in the roughTOEnail is a jewel in the roughTOEnail is a jewel in the roughTOEnail is a jewel in the rough
so i finally got off my *** and took pics of the harness that came with my fogs. i need help determining where each connector goes.
i already know where some of the connectors go but there's 2 with the white question marks that i need help on.
Old Jan 7, 2009
e-z's Avatar
e-z
e-z is an unknown quantity at this point
Re: i need help with foglight harness!!
I think the white one with the black cap might be your ground, and maybe the other one to your fog light? idk im just guessing so dont take my word 4 it just yet
Old Jan 7, 2009
TemjinX2's Avatar
i'm guessing the yellow is ground. the red with the yellow top is the 12v constant. the red with the green head that connects to the fog switch is the 12v trigger.
Old Jan 7, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
There is a DIY somewhere whether it is on this site or another.
Old Jan 8, 2009
cim's Avatar
cim
cim is an unknown quantity at this point
there's a few possibilities on how it is wired up in the loom. You're best bet is to get a multimeter/ohmmeter and look for continuity between the relay pins and the various wires (terminals 30/85/86/87/87a on the relay). Once you have that then we can construct the wiring diagram and tell you exactly what exactly each should hook up to.
Old Jan 8, 2009
TOEnail's Avatar
so ones the ground and the other is a constant 12v. is there a place where it connects to or do i need to splice some wires?
Old Jan 8, 2009
EBP02em2's Avatar
EBP02em2 is on a distinguished road
Looks like I'm gonna need some help too cuz I think I have the same foglight and harness on its way. You ordered these from euroek, correct? There were no instruction manual that came with the box or something?
Old Jan 8, 2009
TOEnail's Avatar
yep..got em from euroek and came with no instructions. =\
Old Jan 8, 2009
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i know exactly where that goes!!! hehehe
look above ur left foot rest pad....there should be a plug that looks just like that....so there fore u have to remove the wire on ur harness...and plug it into the existing car plug
Old Jan 8, 2009
^^^^ is withe white plug w/ red wire
NOW, brown plug w/ white wire....plugs into the interior fuse box...there should be only 1 space that fits it
Old Jan 8, 2009
TOEnail's Avatar
now when u say remove the wire, that means i need to splice the red wire onto the one thats above the left foot rest right?
Old Jan 8, 2009
BJanzen's Avatar
Pull the wire out of that plug and put it in the other (the one in the car already) i believe.
Old Jan 8, 2009
^^ yes what he said....there's a way to pull out the wire W/O damaging the end of the wire....then u can just put it into the existing plug.
nice and clean....no cutting
SO DO NOT CUT AND SPLICE....what if it doesnt work...u can still have the complete wire harness
Old Jan 8, 2009
TOEnail's Avatar
icic...thanks bro!
Old Jan 9, 2009
EBP02em2's Avatar
Hey TOEnail, do you think you can provide me with a DIY on these foglight harness? I'll be installing them myself as soon as it gets here. I hope everything will work out just fine.
Old Jan 9, 2009
TOEnail's Avatar
ill try but really dont have a camera on me right now. i had to borrow my friends to take those pics.
Old Jan 9, 2009
EBP02em2's Avatar
Oh I see. Well, if you do get the foglights to work just let me know. More than likely, I'm gonna need some help with mine. Thanks!
Old Jan 9, 2009
EBP02em2's Avatar
Hey Toenail, I can help you with your foglight harness. You got PM!
Old Jan 9, 2009
TOEnail's Avatar
makes things alot easier..ill try to have these fogs installed by monday. if you need help just send me a pm.
Old Jan 10, 2009
EBP02em2's Avatar
Alright, bro! Hope everything works out.
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Skunkone
Sep 24, 2015 04:38 PM
rob2905
Sep 8, 2015 01:26 AM
