i need help with foglight harness!!
so i finally got off my *** and took pics of the harness that came with my fogs. i need help determining where each connector goes.
i already know where some of the connectors go but there's 2 with the white question marks that i need help on.
Re: i need help with foglight harness!!
I think the white one with the black cap might be your ground, and maybe the other one to your fog light? idk im just guessing so dont take my word 4 it just yet
i'm guessing the yellow is ground. the red with the yellow top is the 12v constant. the red with the green head that connects to the fog switch is the 12v trigger.
there's a few possibilities on how it is wired up in the loom. You're best bet is to get a multimeter/ohmmeter and look for continuity between the relay pins and the various wires (terminals 30/85/86/87/87a on the relay). Once you have that then we can construct the wiring diagram and tell you exactly what exactly each should hook up to.
so ones the ground and the other is a constant 12v. is there a place where it connects to or do i need to splice some wires?
Looks like I'm gonna need some help too cuz I think I have the same foglight and harness on its way. You ordered these from euroek, correct? There were no instruction manual that came with the box or something?
(SnOwBoArDeR | FoReVeR)
i know exactly where that goes!!! hehehe
look above ur left foot rest pad....there should be a plug that looks just like that....so there fore u have to remove the wire on ur harness...and plug it into the existing car plug
^^^^ is withe white plug w/ red wire
NOW, brown plug w/ white wire....plugs into the interior fuse box...there should be only 1 space that fits it
now when u say remove the wire, that means i need to splice the red wire onto the one thats above the left foot rest right?
^^ yes what he said....there's a way to pull out the wire W/O damaging the end of the wire....then u can just put it into the existing plug.
nice and clean....no cutting
SO DO NOT CUT AND SPLICE....what if it doesnt work...u can still have the complete wire harness
icic...thanks bro!
Hey TOEnail, do you think you can provide me with a DIY on these foglight harness? I'll be installing them myself as soon as it gets here. I hope everything will work out just fine.
ill try but really dont have a camera on me right now. i had to borrow my friends to take those pics.
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Skunkone
Sep 24, 2015 04:38 PM
