Anyone know how I could split 1x10 awg to 4x14 awg wires?
Old Jan 6, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Hey guys, I want to take one 10 awg wire from the battery to behind the cigarette lighter area and be able to split that wire to multiple devices. Anyone have a good way to do this? Been searching around but can not find a good way to do this. Rep will be given out whorishly.
Old Jan 6, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Anyone know how I could split 1x10 awg to 4x14 awg wires?
I stripped an excessively long chunk off the end of the bigger wire. Then wrapped the smaller wires around it kind of in a line. Then just smeared tons of solder all over it. Its messy and I'm sure there is a nicer way to do it, but it has worked just fine for me. As long as the wire is plenty big enough for the amount of power you are pulling through it, it should work fine.
Old Jan 6, 2009
BJanzen's Avatar
Yeah, that is how it is now but Im looking to make it so I can add more later. Thanks for the input man!
Old Jan 7, 2009
sl33pyriceboi's Avatar
there are fuses boxes made for this application. its goes from a 2-10awg wire to 4+ smaller wires......all with 4 fuses. we installed it in my friends sound system but i forgot what brand its from
Old Jan 7, 2009
BJanzen's Avatar
O awesome, that will give me somethign to search for. Thanks man. +1 for both of you btw.
Old Jan 7, 2009
TemjinX2's Avatar
just buy a power distribution block..for 4guage to 8 then distribute your devices.
http://cgi.ebay.com/DISTRIBUTION-BLO...3A1%7C294%3A50
Old Jan 7, 2009
BJanzen's Avatar
Too big. Much too big. Looking for same thing but smaller. 10 --> 14 not 4 --> 8
Old Jan 7, 2009
electric130's Avatar
something like this would work:
http://cgi.ebay.com/ebaymotors/NEW-G...5fInstallation
or just buy a terminal strip with jumpers from radio shack.
Old Jan 7, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I've seen distribution blocks like this at Best Buy and some other car audio shops. Stinger makes one that splits 10 gauge to 4 larger gauge.
Old Jan 7, 2009
thats exactly wt mine looked like....but much much much smaller. it was indeed a 10awg to four 12awg wires
Old Jan 7, 2009
TemjinX2's Avatar
yeah i have it my car. i like it because i don't have to use any of the oem wiring or drill into the chasis for grounds.
Old Jan 7, 2009
BJanzen's Avatar
sl33pyriceboi, you know where you got that smaller power block? Looked at my local audio store and they have nothin.
Old Jan 7, 2009
i dont remember sorry, this was years ago....but i know i ordered it online if that helps.
what you could do is buy this: http://cgi.ebay.com/HeavyDuty-Base-A...3D40%26ps%3D48
the left hole (right), put ur 10awg wire (the power)...but cut enough of the tip out, where you can fold it in half, then stick it in the hole. it will fit.
then put the first two fuses in and Y-split the two 14awg wire in the first on the right hole (so two of ur 14awg wire goes in that hole, and yes they will fit)
then put ur last two 14awg wires in the second hole (right)
now you have another hole (the third one, on the right) for future expansion.
just an idea.....
Old Jan 7, 2009
BJanzen's Avatar
Yeah, Ive been thinking about that, thanks man rep'd if i havent already.
Old Jan 7, 2009
BJanzen's Avatar
Well finally found something i guess. Here is what I will be mounting behind my cigarette lighter. Will be nice to have extra power slots for later.
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
Old Jan 7, 2009
BJanzen's Avatar
Actually I got this one:
http://cgi.ebay.com/ebaymotors/ws/eB...1890&viewitem=
SimpleUser
Apr 24, 2021 02:54 AM
exiled1
Aug 8, 2015 06:09 PM
sch2cm
Jul 21, 2015 09:58 PM
Bounddyy
Jul 8, 2015 11:22 AM
robbie374
Jul 7, 2015 02:56 AM
