unknown problem..??
Old Jan 2, 2009
ekboii's Avatar
ekboii is an unknown quantity at this point
unknown problem..??
Hi Im new to the forum so bare with me lol I have a 97 Ex Civic, My problem is that the car idles hard & wants to die out. When I rev the car it wants to hesitate at 3-4K. Ive replaced the Fuel filters, fuel Pump, Spark plug wires. Anyone have any Idea's? Could the Cam Shaft sensor or Fuel rail sensor be an issue also? Thx
Old Jan 2, 2009
AdmireMyGr8ness's Avatar
SuperMod a.k.a ~AMG~
AdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond repute
Re: unknown problem..??
I used to have a similar problem with my Civic. Have you checked the throttle body tension? I'm just taking a stab at it, since I got rid of my Civic a couple years ago...my memory or how I fixed it escapes me. I noticed that mine would also act different when I was running the A/C. Good luck though... my Civic was really pimp and a good car!
Old Jan 3, 2009
ekboii's Avatar
thnxs....
Old Jan 12, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
A) need more info, do you have a check engine light on? B) If A=no, do a ECM reset and idle learn procedure. If A=yes, find out the code it may help.
Old Jan 14, 2009
sql_civic's Avatar
There is no such thing as a cam shaft or fuel rail sensor on your car. If a sensor failed you would get a check engine light. Try cleaning your injectors.
I suggest adjusting your timing and idle and clean your IACV.
How many miles are on this car?
Old Jan 14, 2009
ScottDR's Avatar
Nice catch Sql-There is a crank angle sensor and no cam sensor (this isn't a Toyota like my buddies that left him stranded because of a failed cam sensor). And there certainly isn't a fuel rail sensor of any type that I know of.
Old Jan 15, 2009
guachi's Avatar
guachi is an unknown quantity at this point
check your IACV, make sure that there is no slack on the throttle cable, as the other guy said reset... remove battery for 2mins and place it back in and try it again, make sure that there are no vacuum leaks...
sesi
Oct 1, 2015 02:03 PM
260000milesgoal
Sep 25, 2015 07:41 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
RIPSAW
Aug 16, 2015 12:14 PM
USCGBM
Aug 12, 2015 04:22 PM
