Turbo help
Old Dec 27, 2008
JA7's Avatar
JA7
JA7 is an unknown quantity at this point
Turbo help
i got a 04 civic ex dont know much about turbos can anyone tell me if i have to buy anything more wit this kit.
Garrett GT20 turbo (GT25 turbo for the D17 kits) w/ internal wastegate set to 6 PSI.
Does not require any engine modification.
Bolt-on installation.
Safely produces a 56% gain in horsepower on stock engine internals. This means you will get about 180 to 205 total horsepower, depending on what D Series Civic you have (D15, D16, or D17).
Cast manifold that comes preassembled on Garrett turbo.
Down pipe and gasket.
Polished charge piping.
High-flow intercooler.
Stainless steel braided oil line and fittings.
Stainless steel braided water lines for turbo cooling.
Blow off valve.
Choose from 2 different fuel systems (described above), depending on what your needs are.
Rising rate fuel pressure regulator (not included or needed on 7th Gen Civics).
Heat shield.
High-performance air intake and filter.
Oil return hose and oil pan fitting.
All hardware, pressure lines, hoses, clamps, and couplers.
Installation instructions & injector control settings.
5 year warranty on cast parts, 1 year for accessories, and the full Garrett manufacturer's warranty for the turbo.
Old Dec 30, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: Turbo help
if your wondering why you havent gotten a reply its because these type of questions are asked every other day. use the SEARCH button on the top of the screen. thats your best source. or read the STICKIES in the turbo section.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
