my rear defrost isn't working
Old Dec 20, 2008
rdzlyz's Avatar
rdzlyz is on a distinguished road
does anyone know how to fix this?
Old Dec 20, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: my rear defrost isn't working
maybe you blew a fuse? or the connections got disconnected? there are 2 visible connections (i believe) from the window into 2 small sockets on each end of the window. if all that is good then your rear window is probably defective. it only takes one scratch of the defroster wire (on the window) to ruin it.
Old Dec 20, 2008
d_flore's Avatar
d_flore is an unknown quantity at this point
check ure fuses and the 2 plugs that connect to those black lines that run through ure rear window. they will botgh ends
Old Dec 20, 2008
rdzlyz's Avatar
i checked the fuse in the engine bay, i believe that is the only fuse for the rear defrost, and it is still good. also i never touched those two plugs, i will go check.
Old Dec 20, 2008
CraigW's Avatar
Does the indicator light come on when switched on ??
Can you hear a click from the under hood fuse box when switched on ??
Old Dec 20, 2008
rdzlyz's Avatar
well the light comes on yes but it's just not working, i dont know about the click though.
Old Dec 20, 2008
CraigW's Avatar
The defroster relay is the one just to the left of the large metal case relay at top near center in the under hood fuse box.
When quiet you should be able to hear it and also feel it if you grab the case (have someone turn it on and off with key at position II engine off.
You could try removing it and re-seating it. Also many of the relays in there have the same part # and could be interchanged (keep track of 2 that are swapped)
Old Dec 20, 2008
rdzlyz's Avatar
on the diagram thats on the cover, ill just follow the pictures LOL so i have to get the same relay, it may be the relay i have to see....
Old Dec 20, 2008
rdzlyz's Avatar
well it clicks, the cables are fine, the defrost lines are fine what can be the problem?
Old Dec 21, 2008
a defective window is the only thing left i think.
Old Dec 21, 2008
rdzlyz's Avatar
probably i guess, i dont feel like taking it to honda for repair....i rele dont need it
Old Dec 21, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
the thin wires on the window can easaly be damaged. did u have tint instaled and then removed it? could be it got damaged in the process. use an ohm meter and check each wire for an open.
also theres a antena amp in the passenger side C pillar. that went bad on my coupe and killed radio reception. it's basicly a switch that makes the rear defroster the radio antena when off. then feeds curent though it when on. try replacing that.
Old Dec 21, 2008
rdzlyz's Avatar
i had my tints since 05, i just notice it not working ne more some time dis yer
Old Dec 21, 2008
electric130's Avatar
did you check for power at the connectors on the window?
Old Dec 21, 2008
CraigW's Avatar
You could try swapping relays (quick, easy free)
Check for voltage at the connectors for the windows grid. One side should have voltage present (with defroster on) and the other side is grounded (just use caution working with the connectors on the glass and the grid lines)
Old Dec 21, 2008
they have rear window defroster line repair kits at the auto store if you see one damaged.
Old Dec 21, 2008
rdzlyz's Avatar
the relays are fine, and electric where are the power lines...its on the right side right in the trunk, i can see that there are lines there but its all bundled up...
Old Dec 22, 2008
CraigW's Avatar
So... Do you have voltage and ground at the connectors going to the grid ??
Not sure of the wiring path used for them, But those wires should never flex or be moved much they should not be a problem.
The connectors at the grid may just need reseated or possibly cleaned a bit.
But I would be very careful with them !!
Old Dec 22, 2008
you're not looking in the trunk. you need to pull the connectors off the window and check for power there.
Old Dec 22, 2008
rdzlyz's Avatar
you got it...i have to get me one of them meters...ill borrow one from my uncle till' then ill let you guys know, i work all week so ya....
ORskier
May 3, 2015 12:54 PM
Braun
Apr 23, 2015 09:03 PM
ashleymmackey
Apr 18, 2015 09:48 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
