Need Help Relocating My Spare Tire.. . .
Old Apr 8, 2002
Luck's Avatar
Luck is an unknown quantity at this point
Does anyone have experience relocating the Spare on a 2001 civic coupe? I want to place it
under the car in the back under the trunk. I know it will fit im just having trouble finding the right
bracket that will support the weight. If at all possible I wanted to use the stock bolt. Let me know if
you guys have any tips. Thankx.. . .
Old Apr 8, 2002
mohawkboom's Avatar
I used a 1/4" thick 2x6" Steel plate..bolted each end to the floor pan..Drilled through it and the floor pan...bought a Threaded rod.. Welded it to the plate and cut underneath to desired length.. Used a nut and a steel plate to hol spare in place... used a Wingnut to lock the other nut..
Cheers
Mohawk
Old Apr 8, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
duct tape...lots and lots of duct tape!!!![IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 8, 2002
black's Avatar
black is an unknown quantity at this point
Awesome Post Mohawkboom.
props.
Old Apr 8, 2002
slikor's Avatar
slikor is an unknown quantity at this point
last night i measured the area under my trunk and the stock spare tire would def not fit in there (at least not on my car). unless it was hanging down quite a bit but i dont think that's what you ppl are talking about. wtf, how do you ppl make it fit?
Old Apr 9, 2002
mohawkboom's Avatar
Slikor..it does hang down a bit.. no way around thta without cutting out a hole in your trunk basin and alotta welding..
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
EngiNERD
Aug 12, 2015 09:20 AM
mistermenphis22
Jul 13, 2015 04:43 PM
