vtec head question
Old Dec 8, 2008
LRGhonda87's Avatar
LRGhonda87 is an unknown quantity at this point
Exclamation vtec head question
can i put a vtec head on my 03 civic and how much would it cost
Old Dec 8, 2008
lordhelmet's Avatar
Re: vtec head question
https://www.civicforums.com/forums/1...p-ex-vtec.html
Searching>you. Look around the forums and utilize the search function to answer your questions.
Old Dec 8, 2008
TRIZ's Avatar
The head would be somewhere around 200 bucks, give or take 50 depending on condition. Then if you dont do it yourself, your just paying labor to whoever installs it. You'll also need a new headgasket and the rubber trim that goes around the valve cover which you can get from honda.
Old Dec 9, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Yeah what Triz said, except you will also need either an EX ecu, or a vafc 2, and an FIC if you put a cam in too, then tuning time...its not exactly that cheap I don't think. I would have put mine in already if I didnt have that damn crower cam too
Old Dec 9, 2008
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
on the 01-03 lxs you cant use the ex ecu... unless you put the egr valve with it and all other components... but on the 04-05 it might work because you already have the egr system... i tried that route( my year is an 02) but i needed alot more things than i thought... and it threw 2 codes, the egr and vtec codes...
Old Dec 9, 2008
ryox82's Avatar
I would have always assumed people would just get all the parts....
forgot some people always will try to skimp lol
Old Dec 9, 2008
i didnt... i had the ecu, ex harness, vtec head, solenoid, egr valve... but u still need more.. lol
Old Dec 11, 2008
supafil25's Avatar
supafil25 will become famous soon enough
i have an 02 lx
vtec head swap with vafc2 and crower stage 1 cam.
simply ran 1 wire to the solenoid from the vafc2 for the vtec to work.
Old Dec 11, 2008
sl33pyriceboi's Avatar
its really not worth a "vtec" the minimal power you gain...really.... in the end, its still a slow *** eco-box
Old Dec 14, 2008
dcivic01's Avatar
dcivic01 is an unknown quantity at this point
i did the same swap but did a mild port and polish and decked the head with the vafc2 and it runs alot faster but having problems with the o2 sensors throwing codes
Old Dec 14, 2008
ryox82's Avatar
Originally Posted by supafil25
i have an 02 lx
Wish I could run a stage 2 cam with just a vafc2....
thana
Jun 15, 2020 07:05 PM
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
MiniMi
May 27, 2015 01:57 PM
viper775
Dec 9, 2001 10:52 PM
