03 civic Ac/heater problems
Old Dec 5, 2008
LRGhonda87's Avatar
LRGhonda87 is an unknown quantity at this point
Angry 03 civic Ac/heater problems
so on the passanger side it leaks water inside my car with the ac and the heater on and when i turn it makes a weird noise .. i check the search n didnt find anything help !
anyone from escondido ? that could help
Name:	car problems.jpg
ID:	75391   Click image for larger version
Name:	car problems 2.jpg
Old Dec 5, 2008
Re: 03 civic Ac/heater problems
do you have moonroof? sometimes the plastic tubes get separated and leak water thru the hole.
Old Dec 5, 2008
CraigW's Avatar
Does the water have an odor or color ??
Old Dec 5, 2008
LRGhonda87's Avatar
No sunroof and no color or odor..
Old Dec 5, 2008
i bet its the a/c water drain thats supposed to vent water out the car. do you see water pool up under the car when you park and shut the car off? if not its going inside the car which isnt good.
Old Dec 5, 2008
LRGhonda87's Avatar
Is this an easy fix or should I take it to honda .. N how much this sucks ..
Old Dec 5, 2008
CraigW's Avatar
Sounds like clogged drain hose.
A temp fix and test would be to run the HVAC system without using the compressor (either set to release green A/C light during defrost or use floor setting to keep compressor from running)
The hose exits underneath the car near the firewall.
You may need to locate the sloshing water and try to get it dryed up, It may or may not continue to drain onto floor.
Old Dec 5, 2008
LRGhonda87's Avatar
Thumbs up Re: 03 civic Ac/heater problems
Ok thanks ill take a look thanks for the help
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Braun
Apr 23, 2015 09:03 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
