Oversteer/understeer causes
Old Dec 3, 2008
TRIZ's Avatar
Post Oversteer/understeer causes
The short dummies guide to causes of oversteer and understeer is as follows:
Understeer... you turn wheel, car still goes straight...
Oversteer.. turn wheel and cars *** turns in too much
AND/OR
More traction in rear then front = understeer
More traction in front then rear = oversteer
ALSO
Stiffer front end then rear end = understeer
Stiffer rear end and soft front end = oversteer
AND THAT ALSO MEANS...
more tire pressure in front = stiffer front than rear= more understeer
more tire pressure in rear = stiffer rear than front= more oversteer
Feel free to post up and I'll add to this if you want any more information in here. I by no means am an expert with this, so dont go PM'ing me with a question if you have one, post it for someone else to answer.
Old Dec 3, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Oversteer/understeer causes
something better in the autox FAQ nooblet.
And understeer, the car doesn't always go straight. The car can actually "dive" sideways as the front end pushes forward.
Old Dec 3, 2008
TRIZ's Avatar
I looked through your suspension faq AND autox faq, didnt come across it... please point it out.
Old Dec 3, 2008
robbclark1's Avatar
http://www.wtrscca.org/tech.htm#suspension
This one wasn't there because I didn't realize that Mike Kojima's page had changed...maybe you can update the thread with this link.
http://www.se-r.net/car_info/suspension_tuning.html
Old Dec 3, 2008
TRIZ's Avatar
added
Old Dec 4, 2008
Zzyzx's Avatar
Autocross Junky
Simply put, the #1 cause of all handling problems, be it Understeer or oversteer is Driver Error.
Trying to carry too much speed in to the turn, improper trail breaking, trying to add throttle too soon... ect ect ect...
Sadly there have been very few instances where I've helped someone tune a car where the problem couldn't be traced back, at least in part, to driver error.
on the flip side, there are very few handling problems that cant be fixed by adjusting your driving style...
Old Dec 8, 2008
dietcola's Avatar
dietcola is an unknown quantity at this point
In drift cars... the more grip the better controll and thus longer drift one can pull off.... hence why drift car specialise in oversteer with hard/ solid slip diffs, hard suspension and strut brases, decent/brilliant tyres to boot!
Old Dec 8, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ im not flaming you or anything but this is a civic forum why post about drifting?
nice post triz!
Old Dec 8, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
nice post triz!
Drifting is a controlled power slide. Can be performed on any vehicle including FF's.
Old Dec 8, 2008
Zzyzx's Avatar
Autocross Junky
Que drifter elitist response in 3.. 2... 1....
Old Dec 16, 2008
dietcola's Avatar
surley when talking about understeer and oversteer drifting is relavent?, if not, apologies
