something loose??
Old Nov 28, 2008
02civicg5's Avatar
02civicg5 will become famous soon enough
something loose??
hey i just dropped my car on tokiko and eibach sportlines and as soon as i dropped it, i started hearing a popping and rattling sound coming from my driver side strut.. it only happens wen im making a turn and hit a bump.. beside then it never happens.. it feels like something is loose.. im not sure wat it could be..
Old Nov 28, 2008
02civicg5's Avatar
Re: something loose??
can anyone pleaz help?? been searching and searching but nothing
Old Nov 29, 2008
robbclark1's Avatar
Retired suspension supermod.
Did you put the top hat on the right way?
Di you get under your car to check if everything was tight?
Old Nov 29, 2008
02civicg5's Avatar
well i got it assembled already.. all i did was just replace on bolt it on.. i mean ive heard that if the top and bottom arrows are not aligned u were gonna hear poppin, i dunno if u understand wat im trying to say
Old Nov 29, 2008
02civicg5's Avatar
i only get the noise wen im turning and hit a bump or something
Old Nov 29, 2008
FALKEN's Avatar
Civicforums Junkie
poor install
you must index everything exactly the way it was as OEM to avoid the binding
Old Nov 29, 2008
robbclark1's Avatar
check to see if the spring is seated all the way.
Also check you didn't over/under torque the nut on the top of the shock.
Old Nov 29, 2008
02civicg5's Avatar
ok thanks alot... ima check up on this and get bak
GolNat
Nov 27, 2018 03:32 PM
Tyler93
Mar 20, 2016 09:03 PM
Joecrowe
Sep 24, 2015 09:12 AM
bashea
Sep 15, 2015 04:59 AM
MichaelLW
Sep 14, 2015 07:15 AM
