1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
89 civic 1.5 will not start after driven
Old Nov 16, 2008
cyapeepn's Avatar
cyapeepn is an unknown quantity at this point
Question 89 civic 1.5 will not start after driven
After car has been started and driven once its turned off it takes about 3 minutes before I can start it again. My wifes friend has the exact model with the exact problem. I changed the cap & rotor, plugs & wires. No luck. Anyone else that has had this trouble, can you please let me know what you did to correct it?
Old Feb 19, 2009
Civvyftw11's Avatar
Civvyftw11 is an unknown quantity at this point
Re: 89 civic 1.5 will not start after driven
100% sure its your main fuel relay.
its a pretty easy fix but its pricey, the main fuel relay is located under ur fuse panel to the very left of the drivers side. what you gotta do is take out your coin box, take off the fuse panel and then there will be another 10mm bolt right infront of you connecting most of the panel together i suggest taking this bolt off because it allows for more movability. Anyway once thats done its time for the hard part, this entire thing has to be done upside down. Unscrew your hood release again for an easier access and to the left of the hood release will be a 10mm nut. This is the only nut you have to unscrew but you need a smaller ratchet in order to unscrew it, also like mine yours may be some what rusted out so you have to giver but not too hard or else it breaks. then once thats done you have to maneuver around to get the main relay out and replace it. Depending on how much longer you want to have the car you can buy a used one. Mine cost around 95$ cad.
http://www.tegger.com/hondafaq/mainrelay.html
thats a good site if u need some more help
mattdoc
Mar 14, 2017 12:10 PM
tylerginevan
Apr 27, 2015 12:29 PM
15EXCoupe
Apr 19, 2015 09:26 PM
Richkid23
Apr 19, 2015 12:53 PM
SSMatey
Apr 13, 2015 06:09 PM
