Fuel injectors cleaners + problems
Old Nov 8, 2008
eng. tariq's Avatar
eng. tariq is an unknown quantity at this point
Question Fuel injectors cleaners + problems
Hi all,
I have a question regards the Fuel injection cleaners, will they harm the car performance?
For my situation, I used Chevron Fuel Additive and STP fuel injection cleaner. and I put it on the tank, I notice the following:
1- The car is getting lazy (lost some power).
2- The gas mileage going down, from 397/34 to 30/29 .
3- The car starts idling on 400-450 not as usual 550-600 (but it does not hesitate or satel down) (not all the times, some times at the stops and traffic lights)
I feel that the car is running rich!!! but i do not know (the exhaust tip is silver color original but now it is dark black) and i did not notice any type of smoke, but i smell fuel some times)
The only things that I did in the same time were installing Greddy Evo 2 Cat-back muffler, changing the car oil (i think they used a regular oil not a synthetic blend oil) and changing the cone filter on my SRI (I used an AEM filter).
I have another problem, the turn signal hand on the steering wheel is not returning back to off after straightening the wheel, if there is any way to fix this issue also (it works some days then stop then come back to work again)
Please advice me to fix these problems.
Thanks.
Old Nov 8, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
Re: Fuel injectors cleaners + problems
ya, u might be running rich.
id say replace ur 02 sensors. maybe it cleaned ur injectors alot and the parts dirtied ir sensors and now they are making ur run rich and just making it worse. mine is doing the same thing and im changing the sensors next week.
i can smell the gas when i idle.
Old Nov 8, 2008
eng. tariq's Avatar
I do not have any CEL at all regards the O2 sensors
will cleaning the O2 sensors be a good idea?
Old Nov 8, 2008
all the stuff in store is garbage. try lubecontrol.com fp-plus in the gas and lc20 in the oil. you wont regret it. i been using for almost 3 yrs with excellent results.
Old Nov 8, 2008
eng. tariq's Avatar
I have not been using any of these stuff before in the car and the only time i used STP cleaners/Chevron Fuel Additive: Techron Concentrate but i get these symptoms
what i a thinking is that the dust and dirt from the injectors reach th O2 sensors and block or some thing like that, is there ay way to check that or fix it?? is my tough correct??
thanks
Old Nov 9, 2008
if the o2 sensors are bad, they must be replaced. its very delicate and if anything spills or contaminates them, they wont work. no way to clean them
Old Nov 9, 2008
Krieger's Avatar
what exactly do those lube control things do exactly? i mean, are they really worth buying and using? is there any info (other than their own site) on it that says it works?
i might pick some up if it really does help.
Old Nov 9, 2008
eng. tariq's Avatar
yeah, i need that too
how do i check the O2 sensor while there is no CEL in my car??
Old Nov 9, 2008
oh theres no cel? then the sensors are prolly fine. the light will come on if theres any problem with em.
the lubecontrol.com stuff is just extra maintenance to keep the engine and fuel system clean. it is not a harsh cleaner, it works slowly and then keeps the car in good shape so long as you keep using it all the time. i recommend the gallon jug of each cause its way cheaper than the small bottles.
Old Nov 9, 2008
WannaBFast's Avatar
Prowlin' with a Purpose
try adjusting your valves? if ya got a lot of miles on them, the valve clearance probablly is getting pretty loose causing a drop in performance and such
Old Nov 10, 2008
Elemental08's Avatar
Elemental08 is an unknown quantity at this point
Have you tried simply replacing your fuel filter(s)? Sometimes fuel additives will clean the gunk out of the fuel system and the gunk will collect in the filters (good proof that the filters are doing their job.) Change the filters and check them again in about 300 kms to see if they need to be changed a second time. If there was a lot of gunk in the fuel system you may have to go through a few filters.
I also recommend using a good quality fuel and oil additive. My personal favorite are Bi-Tron products. They seem to lubricate the engine components and the fuel system components quite well. More info here:
www.free-fuel-rewards.com
Old Nov 10, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
Actually there the fuel filter is in tank on 7th gen elemental.
Old Nov 10, 2008
Krieger's Avatar
ya, its in the tank and its a bitch to get to.
and i doubt its his valves.
change ur sensors. its like 50 a piece. and it should help. and if it doesnt, u know its not that
Old Jun 26, 2009
02_civiclx's Avatar
02_civiclx is an unknown quantity at this point
I'd say, stay the heck away from putting more chemicals in your engine.
Old Jul 4, 2009
ozzy's Avatar
ozzy is an unknown quantity at this point
On the contrary, certain chemicals are a good thing when used in the proper combinatoric ratio. Most people don't read instructions and throw their whole bottle into the tank. I swear that seafoam is the schitt, but too much can damage fuel delivery components.
docmartin14
Jul 30, 2015 11:26 AM
green01civic
Apr 29, 2015 01:36 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CiviCKiD
Jan 7, 2002 01:30 AM
