Overheating. HAs me stumped
Alright so the other day I was sitting in a parking lot with my car on listening to music and happened to look down and noticed my temp was hot, hotter then usual that is. I read around bc this is the first cooling problem I ever had and found that maybe the fan wasnt working.
I check one time and it wasn't on so I tried replacing the relay with another one. Then it came on. then I switched the relays again and it came on again. Now I just went for about a 3 hr drive and no cooling issues. It wasactually running cooler then normal maybe by a few degrees but still. I sat in a parking lot letting my car run and it startedheating up again. This time the fan was running. I have talked to plenty of people and they are stumped. Even the mechanics I've talked to.
Any suggestions? Its not realy a big deal if it only heats up in a paring lot. But this may lead to other problems. Thanks in Advance.
Re: Overheating. HAs me stumped
I eliminated the possiblity of th thermostat bc When Im riving it reman cool. from what I understand a faulty thermostat would cause overheat problems either at random or just all the time. I also tried to check by making sure the coolant was cycling around by feeling both rad hoses and both were warm. Maybe its weird and stops working when I sit. The other thing too is that with a bad thermostat wouldnt it take a while for the car cool once i start moving again? As soon as air starts flowing thru the car, as in me moving, it cools almost instantly.
right, if it was half open, it could cause this, half open, half closed, blocking proper flow at idle, then waterpump kicks in when driving, sending more coolant through, its my only thought
Alright Ill have my mechanic check it out but i didnt wanna have anyone do it bc i dont have a lot o money. I may just get some buddies to do it. Any other thoughts if that doesnt solve it?
UPDATE: Just replaced my thermo and the heating issue not only went away but it only takes about 2 - 3 mins to heat up now. Thanks a lot everyone. Another problem I had was so that my car wouldn't overheat, I would let it run til it got hot then shut my car off. But when I went to turn my car on, the battery would be dead. I bought a new Optima and loving it. No more problems and the battery lasts twice as long when I run it dry. Hopefully this helps everyone.
Hopefully that is all you need. Just make sure after you replace the thermostat that you top off your antifreeze and remove all air bubbles from your coolant. If you don't, it is possible to have problems that seem worse then before you replace the thermostat. Good Luck.
solarpunk70
Apr 12, 2016 11:43 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
Civic720
Sep 10, 2015 10:06 AM
Ronin Nishimura
Jul 28, 2015 07:24 AM
Green02civic
Jul 27, 2015 10:48 PM
